tony359
May 09, 2014Apprentice
Switch advice please
Hello, Having verified that my Virgin Media 'Super Hub' is not the best as a switch, I was thinking of getting a decent one which I may use for some years when/if my network expands. I like the ide...
May 20, 2014Guru - Experienced User
I'm not sure which switch you got. But the Netgear smart switches can also be configured using http, so maybe try that. You should be able to see the switch IP address in your router.
