Grimleiv
Apr 10, 2024Tutor
Sync time with and without network connected.
Hi Will sync go faster with network fable disconnected? I just reset my R104.. due it took dor ever.. like 300+ hours to synd 2 x 10TB and 2 x 12TB disks.. Thought with reset and total n...
- Apr 10, 2024
Not really. The sync does run at a lower priority than file transfers, so if you use the NAS heavily it can take longer. But just connecting it to the network won't affect the running time.
Thought with reset and total new X-Raid.. it would go faster..
It has to access every sector on every drive, so it will be doing 42 TB of disk I/O. So it will definitely take a while.
The time shown in the web ui is just an estimate.
Apr 10, 2024Guru - Experienced User
