bryceee
May 08, 2022Aspirant
Sys fan failed on RND4000v2 - READYNAS NV+ v2
My NAS fan appears to have died with message "SYS fan failed" on the NAS uint. When I connect a good fan it also doesn't work. There is 5v on the yellow wire pin and 0v on the other two (red and bla...
- May 09, 2022
First, let's confirm the model.
- Does your NAS say ReadyNAS NV+ on the front panel?
- Or does it say ReadyNAS NV+ v2 on the front panel?
bryceee wrote:
What are my options?
Even if I buy a new NAS, will I be able to insert my old disks without it wiping the data?
If you were running 2x2TB XRAID, then you actually are running RAID-1. One option is to connect one of the disks to a Windows PC (either with SATA or a USB/SATA adapter/dock), and then use freeware (R-linux for Windows) to copy the data to a PC or USB drive. https://www.r-studio.com/free-linux-recovery/
You won't be to migrate the disks directly to a new NAS - so you'd need to purchase a used NV+ v2. Netgear stopped producing your NAS around 9 years ago, so anything you purchase would be 9-11 years old. If you go this route, be careful that you get the right model. The original NV+ (called a v1 here), and the v2 are not compatible - you can not migrate your disks from one to the other.
May 09, 2022Guru - Experienced User
bryceee
May 09, 2022Aspirant
I managed to get the UI to work briefly (see pic)
Other than no fan (I have a large pedestal fan aimed at it) and the UI not working disk seems to be holding. I'm rsyncing changes across to one of my backups now <crosses fingers>. Last backup was 2 months ago (its stored remotely) and I don't use it much so it won't be a huge deal if I lose all the changes.
If that fails, I will go the r-linux route.
Really appreciate the reply - assumed with xraid I'd need both disks to be able to recover the data, so knowing I don't is a huge relief!
Cheers!
- StephenBMay 09, 2022Guru - Experienced User
I think you should also be able to power the fan externally, instead of from the system board. There are a couple of options out there for that - both using USB and mains power. You'd lose speed control, as the fan would be always on.
Sandshark might have some troubleshooting suggestions.
- SandsharkMay 09, 2022Sensei
Wire colors can be inconsistent between manufacturers, and I don't have an NV+V2. So is the red wire in the center (pin 2)? That's the normal lay-out, and pin 2 should have between 5V and 12V on it, but the default at start-up should be 12V. The yellow wire (assuming it's pin three) is the tachometer input.
A little board like this one https://www.amazon.com/ALEDECO-Voltage-Motor-Speed-Controller/dp/B07P2BLG2L would allow you to set the fan to something less than full speed, and you could tap 12V from the input connector or use a separate (maybe variable voltage, so you don't need the board) supply. Or you could create something yourself -- it's just a variable voltage divider.
Here is a good write-up of the fan pin-out. https://allpinouts.org/pinouts/connectors/motherboards/motherboard-cpu-3-pin-fan-connector/ . Note that the first picture shows a non-standard color usage (though the legend contradicts it).
