bryceee
May 08, 2022Aspirant
Sys fan failed on RND4000v2 - READYNAS NV+ v2
My NAS fan appears to have died with message "SYS fan failed" on the NAS uint. When I connect a good fan it also doesn't work. There is 5v on the yellow wire pin and 0v on the other two (red and bla...
- May 09, 2022
First, let's confirm the model.
- Does your NAS say ReadyNAS NV+ on the front panel?
- Or does it say ReadyNAS NV+ v2 on the front panel?
bryceee wrote:
What are my options?
Even if I buy a new NAS, will I be able to insert my old disks without it wiping the data?
If you were running 2x2TB XRAID, then you actually are running RAID-1. One option is to connect one of the disks to a Windows PC (either with SATA or a USB/SATA adapter/dock), and then use freeware (R-linux for Windows) to copy the data to a PC or USB drive. https://www.r-studio.com/free-linux-recovery/
You won't be to migrate the disks directly to a new NAS - so you'd need to purchase a used NV+ v2. Netgear stopped producing your NAS around 9 years ago, so anything you purchase would be 9-11 years old. If you go this route, be careful that you get the right model. The original NV+ (called a v1 here), and the v2 are not compatible - you can not migrate your disks from one to the other.
