mandakh
Apr 11, 2018Aspirant
System volume root's usage is 81%. This condition should not occur under normal conditions.
Having trouble with System volume root's usage is 81%. Can i move / delete /var/lib/mysql folder?
- Apr 11, 2018
Thanks again!
mdgm-ntgr
Apr 11, 2018NETGEAR Employee Retired
You need to first stop any apps that are using MySQL, then stop MySQL itself, move the MySQL directory to an appropriate directory on the data volume, then create a symlink and turn MySQL etc. back on.
Or if you don't need any of the apps that use MySQL anymore or MySQL itself you can uninstall them all then delete the MySQL databases if they are left behind.
- mandakhApr 11, 2018Aspirant
Thanks for your respond.
I wonder /var folder related with System volume root's usage is 81% issue?
Do i need to remove / change some folder under /dev/ path?
