Ruben_Rocha
Jan 26, 2018Aspirant
temporary use of drive for test
Just purchaced a rn316 readynas. I have 3-3tb wd red drives installed and all seems okay using xraid. Showing 8.71 tb total space.as raid 5 I have already copied data to the drives. My question i...
- Jan 26, 2018
What you need to do is set the NAS to use flexraid - then it won't automatically add newly inserted disks to the existing data volume.
Then you can insert a disk, create a temporary volume, run the disk test, etc. Just delete that temporary volume before you remove the disk.
An alternative is to power down, remove all your working disks (labeling them by slot), and then put your test disk in the slot you want to test. If the disk is blank, you can just power up. If it isn't blank, do a factory install from the boot menu. If that works, then the slot is fine.
Then done, just power down, put your working disks back (removing the test disk), and power up again.
wrote:
Does it matter which bay I place the 4 or 1 tb drive in
No, you can use whatever bays you leave empty.
Jan 26, 2018Guru - Experienced User
- Ruben_RochaJan 26, 2018Aspirant
Okay that makes sense. I don't want to loose three days worth of copying. to just test the bays if they are okay.
Thank You.
