Ruben_cc
Aug 08, 2012Aspirant
Thanks for the safety-options!
Since this forum is primarily used to ask questions and complain about things that don't work, I thought it would be nice to place a big thank you to NetGear for putting various safety-options inside ...
beisser1
Aug 09, 2012Tutor
hmmm quite a hot harddrive you have there.
two possible reasons for this obviously wrong info.
1. the harddrive records/gives wrong information in its smart info.
2. the software reading the smart info from the disks has a bug.
most likely its option 1. what type of harddrive gave you that kind of temperature reading?
