theGuitarGuy
Aug 05, 2016Aspirant
Tired upgrading RN-102 to latest firmware, it seems bricked...
My RN10200 stoped working with Time Machine, i thought this might be due to firmware (unlikely i haven't updated anything on my Mac or NAS). Anyway i decided to update it, as it hadn't been updated b...
mdgm-ntgr
Aug 05, 2016NETGEAR Employee Retired
Have you checked your disks to see if one of them is bad?
You can hook them up to your PC and test a SeaGate disk using SeaTools or a WD disk using WD Data LifeGuard Diagnostics
- theGuitarGuyAug 09, 2016Aspirant
Sorry I should have mentioned.
both the disks are working fine and it's been tested with a different disk as well, with no result...- mdgm-ntgrAug 09, 2016NETGEAR Employee Retired
Using the upload button on the apps tab is for installing apps.
For installing firmware there is an option under System > Settings > Update to manually install a firmware update.
