alsalmioxy
Oct 29, 2016Aspirant
To select the right ReadyNAS for my Axis Camera
Hello everyone!! I'm new to ths form. I need to buy ReadyNas for my Axis cameras and I have different brands of Axis like P1405-LE/ P3214/ M3046-V and also some other Brands like Dahua and Hikvision...
Oct 29, 2016Guru - Experienced User
alsalmioxy wrote:
Also do you I need to buy any licenses to connect theses cameras?
Are you planning on using ReadyNAS Surveillance? That is a licensed application that you would need to purchase.
Though many cameras have built-in support for writing to NFS or SMB data shares, so you don't necessarily have to use Surveillance.
There is more information on ReadyNAS Surveillance here: https://www.netgear.com/business/products/storage/readynas/readynas-surveillance.aspx
Supported cameras for Surveillance are here: http://www.downloads.netgear.com/files/GDC/RNNVR01L-1000S/ReadyNAS_Cameras_DS_28Feb14.pdf
alsalmioxy
Thank you for the support -
Basically I need a storage area to record the video.
I know Axis has their own application which can be installed in the mobile but is it possible to connect this application to the ReadyNas and play back any video?
Thanks.
- StephenBOct 29, 2016Guru - Experienced User
I'm not an expert on Axis. But if Axis Companion software does what you want, then you could use it with a ReadyNAS.
You'd need to install the Axis software on a PC (which would need to be on 24-7). Then you can mount a NAS network share as a PC drive letter, and use it as if it were local. Axis Companion might also directly support NAS network shares (I never used it, so I don't know).
Their recommendations are here: http://www.axis.com/us/en/support/faq/FAQ115869 A ReadyNAS RN314 meets these requirements (as do the RN500 and RN600 series). WDC Red Pro disks would be suitable; you could also use WDC purple drives which are designed for surveillance.
Though AXIS recommends Intel processors, the RN214 also has enough performance to do this job.
AXIS recommends a UPS - which makes sense for any NAS. You can protect the PC and the NAS with the same UPS if you get one of reasonable size. I use Cyberpower myself, many people also like APC.
- SandsharkOct 30, 2016Sensei
If the AXIS software runs as a service (with a different user name than that with which you normally log in, such as SYSTEM), you would need to map a drive that is accessable to that user. Drive mappings are user-specific in Windows, and running such applications as a service is common so that it runs even with no user logged in. Mapping a drive that is accessible to SYSTEM is not trivial (I'm not sure the old methods for doing it still work under Win10), but it can be done via a startup task if you can specify a different user name for the service. Using a symlink is sometimes a better option in these cases, as that is user independent unless you place it in "My Documents" or anywhere else user access is restricted.
Personally, I use Blue Iris as my software for a mix of cameral types. It's quite reasonably priced, but does require that you have a PC on which to run it, but so would the Axis software unless there is a Linux version. I use a ReadyNAS as the backup device for the files. Since I can remote into the software to view files, there is no need for instantaneous NAS storage of the files. And since it's a backup process, not a continuous one, NAS speed and availability are not important factors.
With a fast enough NAS with enough memory, I suppose the camera software (Blue Iris, Axis, or whatever) could run in a virtual Windows machine on the NAS. But having a separate real PC is just way simpler and cheaper unless you have another reason for such a capable NAS.
- StephenBOct 30, 2016Guru - Experienced User
Sandshark wrote:
...Mapping a drive that is accessible to SYSTEM is not trivial ...
I agree.
But since AXIS goes to the trouble of providing specifications for suitable NAS, I figured that their software likely wouldn't require heroics to configure a network share for their video repository.
