edb15
Dec 15, 2014Aspirant
Transferring from Mac (HFS+) formatted USB drives to NV+
For my music library, I've been running 500GB, 1.5TB, and 3TB USB external drives connected to my Apple Airport Extreme. I have acquired an NV+ (2007 Infrant version) which I intend to use for that p...
RX
Dec 15, 2014Luminary
Its not advisable that you insert your drives directly to your ReadyNAS NV+ or to your ReadyNAS Ultra4 because the data might be all wiped out.
It would be best that you back up first the data stored in your existing drives then format them into NTFS format then insert them to your ReadyNAS NV+ then store the files you want.
