TheTomahawk
Jun 23, 2016Aspirant
Transition from ReadyNAS Duo v1 to ReadyNAS 104
I'm considering upgrading my Duo to a newer model. I have 2x1TB drives currently in the Duo, and would prefer to not have to but new drives just yet. Can I just take these 2 drives and put them ...
- Jun 23, 2016
Hello TheTomahawk,
Your current ReadyNAS is a Sparc-based OS4 NAS while the RN104 is an OS6 NAS. You cannot use the same disk and expect the data be intact. If you can still access the data, back up first. You can still use the same disks with RN104 but it won't keep the data, it needs to format the disks since these disks were used on a different platform and OS.
Although you can try using the same disks after formatting them, there is no guarantee that they will work as they should with the RN104 if they are not listed on the HCL. It is recommended to check HCL first when using ReadyNAS systems so you know which disks to get.
TheTomahawk
Cool. Thanks. I'll try that when I buy it.
JennC
Jun 23, 2016NETGEAR Employee Retired
Hello TheTomahawk,
As StephenB mentioned, you can use RSYNC protocol. See How do I back up data from a RAIDiator 4 system to a ReadyNAS OS 6 system? article. However, this will not backup the permissions.
- StephenBJun 23, 2016Guru - Experienced User
If it doesn't, then I'd say that's a bug.
