TheTomahawk
Jun 23, 2016Aspirant
Transition from ReadyNAS Duo v1 to ReadyNAS 104
I'm considering upgrading my Duo to a newer model. I have 2x1TB drives currently in the Duo, and would prefer to not have to but new drives just yet. Can I just take these 2 drives and put them ...
- Jun 23, 2016
Hello TheTomahawk,
Your current ReadyNAS is a Sparc-based OS4 NAS while the RN104 is an OS6 NAS. You cannot use the same disk and expect the data be intact. If you can still access the data, back up first. You can still use the same disks with RN104 but it won't keep the data, it needs to format the disks since these disks were used on a different platform and OS.
Although you can try using the same disks after formatting them, there is no guarantee that they will work as they should with the RN104 if they are not listed on the HCL. It is recommended to check HCL first when using ReadyNAS systems so you know which disks to get.
TheTomahawk
49% of 1.8TB used, so around 900GB. 2x2TB drives mirrored (xraid).
- aksJun 23, 2016Virtuoso
It sounded like this is your only copy of the data, but do you have a backup or a PC with space for one?
