aalexandrebeta
May 31, 2016Master
Tray adaptator for SSD
I was wondering if someone can help me in finding a tray to switch from standard HD to SSD for a future NAS purchase.
- May 31, 2016
All our current ReadyNAS come with drive trays that can hold 2.5" drives. When using 2.5" drives you will need to use the included screws. Screws are not needed when using 3.5" disks.
cpu8088
May 31, 2016Virtuoso
ssd drives are just the same as 2.5 inch hard drives. any tray that can hold 2.5 inch drive will do
- mdgm-ntgrMay 31, 2016NETGEAR Employee Retired
- aalexandrebetaMay 31, 2016Master
Thanks for the quick answer guys!!!!
