RaedyNas
Oct 06, 2020Aspirant
Troubleshoot Hanging / Incomplete Scheduled Shutdown ReadyNas Pro
Would like help troubleshooting why the readynas doesn't complete a shutdown with the scheduled shutdown. Unit is scheduled to shutdown at 1 am. Sometimes the unit will be found unresponsive in t...
Sandshark
Oct 07, 2020Sensei
Try turning it off via the GUI and see if it does the same thing and if any messages are printed on the display.
You may have a failing power supply. Specifically, the +5VSB (+5 volt standby) power portion of it, which is what stays on all the time to power the power-on/off circuit. But it's a bit early to jump to that conclusion.
- RaedyNasFeb 10, 2021Aspirant
Sandshark,
Thanks for the suggestion.
Posted this about the same time I upgraded the OS from 6.5.1 to 6.10.3. Gave it couple months to see if the "incomplete scheduled shutdown" would happen again. Other change was I switch timer schedule from "state" to "event".
After these 2 changes I haven't had any incomplete scheduled shutdowns.
