cchatterjee
May 31, 2012Aspirant
Trusty old NV finally died, what next?
I have a trusty (well, used to be trusty) old NV (original model, not the +) that suddenly became unresponsive and had disk 2 and 4 lights on, then on a hard reboot it was completely dead. The ques...
cchatterjee
Jun 01, 2012Aspirant
OK, I tried to go into Tech Support mode, but it didn't work (my fault), so I restarted the 1100 to try again and miraculously it has come up with the name and IP of the old NV (and all the other settings like Jumbo Frames) with the array and data just fine!
I've rebooted this thing at least15 times in the last week, but I guess it was your email mojo that did the trick!
So I'm going very gently transfer all the data over to a newer ReadyNAS before anything goes pear-shaped, then the 1100 will be relegated to backups of backups since I don't trust it worth a darn!
Thanks for all the help though, it saved me days (or weeks) of reassembling/transferring/redownloading data! (I hope the magic holds out!)
