pkraiker
Sep 17, 2012Aspirant
Trying to use ST3000DM001 3TB drive in USB dock
I have 4 of these drives in my NV+ and want to use them for backups and/or hot swap for the raid array so I picked up 2 more along with a BlacX eSata dock to use for USB backups. This HDD/dock config ...
pkraiker
mdgm wrote: What version of RAIDiator are you running on the NV+?
5.3.6
When you formatted the disks using the Mac did you make sure to use the GUID/GPT option for the partitioning?
Yes, confirmed (it's the default that shows up selected with exFAT as well as FAT).
