pkraiker
Sep 17, 2012Aspirant
Trying to use ST3000DM001 3TB drive in USB dock
I have 4 of these drives in my NV+ and want to use them for backups and/or hot swap for the raid array so I picked up 2 more along with a BlacX eSata dock to use for USB backups. This HDD/dock config ...
mdgm-ntgr
Sep 17, 2012NETGEAR Employee Retired
Via SSH if you do a
You should see the USB disk listed.
You could then umount it and try formatting it if you like using e.g.
(This is assuming the USB disk is /dev/sdi)
# cat /proc/mounts
mkfs.ext3 /dev/sdi1
