pkraiker
Sep 17, 2012Aspirant
Trying to use ST3000DM001 3TB drive in USB dock
I have 4 of these drives in my NV+ and want to use them for backups and/or hot swap for the raid array so I picked up 2 more along with a BlacX eSata dock to use for USB backups. This HDD/dock config ...
pkraiker
Sep 18, 2012Aspirant
mdgm wrote: Yes, the 'root' password is set to the 'admin' password when you install EnableRootSSH though the root user is a separate user to the admin user and you can change their passwords separately.
Once I'm able to successfully log in! Which I just did... I needed to specify the login name on the ssh command line. DOH
Thanks mdgm, for your help and your patience. Now let's see if i can correctly format the drive.
