pkraiker
Sep 17, 2012Aspirant
Trying to use ST3000DM001 3TB drive in USB dock
I have 4 of these drives in my NV+ and want to use them for backups and/or hot swap for the raid array so I picked up 2 more along with a BlacX eSata dock to use for USB backups. This HDD/dock config ...
pkraiker
Sep 18, 2012Aspirant
mdgm wrote: You might need to do
apt-get update && apt-get install parted
or something like that. You can google on how to use it.
Installed. I'll explore the options in the morning. The print shows:
# parted /dev/sde print
Model: Initio INIC-1610P (scsi)
Disk /dev/sde: 3001GB
Sector size (logical/physical): 512B/512B
Partition Table: gpt
Number Start End Size File system Name Flags
1 20.5kB 210MB 210MB ext3 EFI System Partition boot
