NoobGirl
Feb 22, 2012Aspirant
Ultra 2 - discs won't boot - case # 17976549
Ok, firstly, I admit that I am completely new to the NAS world and only have a couple of months experience. I'm usually successful at troubleshooting myself, but I am stumped as to what went wrong. ...
mdgm-ntgr
Feb 22, 2012NETGEAR Employee Retired
When you shut off the NAS did you disconnect the power afterwards. If not, try this. A cold boot after a period where the power is disconnected from the unit is worth a try.
Please contact tech support (http://www.readynas.com/support) and edit the thread title (i.e. subject of first post in the thread) to include your case number.
Assuming that it isn't a disk problem is a bad assumption. Disks can and do fail at any time. Whilst it may appear that the disks aren't the problem one cannot just assume that.
