mrQQ
Feb 05, 2019Apprentice
Ultra 4 + OS6.9.5: biggest supported HDD?
Hi,
I know I have legace hardware, but it's running newest OS greatly. Do you have any clue what would biggest supported disks be? 8TB? 12TB? 16TB?
Thanks.
- Feb 14, 2019
Hi mrQQ
All actual OS 6 devices are able to run at any capacity including legacy units running on OS 6 they shouldn't have a limit but there are some rackmount legacy unit that has a limit with capacity.
This means if you are running OS 6, you can use the largest capacity without any problem though RN100 or RN200 units might have performance impact when running large capacity disks e.g Sync time etc
Hope this helps!
Regards
Sandshark
Feb 05, 2019Sensei
Something well beyond what is currently available. Netgear has not given an official number.
- DhrDemesmaekerFeb 09, 2019Guide
I have a readynas Ultra 6, running OS6 and I installed 2 x 10TB. Works great.
