Ripperoo
May 21, 2011Aspirant
Ultra 4 Plus Memory Upgrade Advice Needed
I finally got myself a ReadyNAS 'Ultra 4 Plus' after what seems like an eternity.
Got it for what I thought at the time was a decent price around two weeks ago for £418 and no it's dropped again to £375. Bummer!
Anyway I'm thinking about upgrading the memory to 4GB, but what do I get?
I come accross several branded 4GB modules which are as follows:
The prices listed above are from independant retailers as opposed to the manufacturers store price.
Also found on a certain auction site:
Still a bit more expensive than across the pond in the US I guess, but these seem to be the best delivered prices I can find for branded modules from known online retailers in the UK.
I did find some "KomputerBay" branded modules which were cheaper, but seem to get mixed reviews.
I understand that some of the above are in fact "PC2-6400 (800MHz)", but can I assume this won't impact on performance and the module will just operate at the lower speed?
Also, if anyone knows of a different reliable brand and model # available in the UK, feel free to add them here.
Thanks guys
Corsair 4GB, 200-Pin SODIMM, DDR2 PC2-6400 (800MHz) - (VS4GSDS800D2) - £63.76
Crucial 4GB, 200-Pin SODIMM, DDR2 PC2-6400 (800MHz) - (CT51264AC800) - £80-39
Crucial 4GB, 200-Pin SODIMM, DDR2 PC2-5300 (667MHz) - (CT51264AC667) - £82.30
Patriot 4GB, 200-Pin SODIMM, DDR2 PC2-6400 (800MHz) - (PSD24G8002S) - £66.24
G.Skill 4GB, 200-Pin SODIMM, DDR2 PC2-5300 (667MHz) - (F2-5300CL5S-4GBSQ) £71.54
Thanks guys
- craffert0AspirantWhile you shouldn't need more than 1GB for running programs, more memory means more disk cache, and for a file server, more memory is ALWAYS useful.
- beglitisAspirantHi,
Do these 4GB modules also work in Ultra 2 (1.5GHz version) as well? Would be good to know because I am looking to upgrade. Before anybody asks, I am using my NVX and soon my Ultra 2 as small Linux servers (running anything from Joomla to MySQL, dovecot/postfix/spamassasin/clamav, postgres etc) so yes I really need the memory :)
Thank you!
Nick - beglitisAspirantForgot to mention that I even run JIRA/Confluence/Bamboo/Perforce in my NVX (I love this thing) but I would be keen to migrate as many things possible to the Ultra 2 to split the load a bit. 4GB would be beautiful.
- fastfwdVirtuoso
beglitis wrote: Do these 4GB modules also work in Ultra 2 (1.5GHz version) as well?
No, but you can upgrade to 2GB. See this thread: http://www.readynas.com/forum/viewtopic.php?f=110&t=52557&start=15#p379994 - beglitisAspirantUnderstood. I thought maybe there was a chance that a 4GB module might actually work (despite the chipset's constraints). I really need to ask someone who knows about hardware design why does size matters in this case... (just out of curiosity)
- fastfwdVirtuoso
beglitis wrote: Understood. I thought maybe there was a chance that a 4GB module might actually work (despite the chipset's constraints). I really need to ask someone who knows about hardware design why does size matters in this case... (just out of curiosity)
You can download the CPU datasheet and see for yourself:
http://www.intel.com/content/dam/www/public/us/en/documents/datasheets/atom-d400-d500-vol-1-datasheet.pdf
http://www.intel.com/content/dam/www/public/us/en/documents/datasheets/atom-d400-d500-vol-2-datasheet-.pdf
And actually, I'm not sure now that the thread to which I pointed you is relevant. I just re-read your original question and I see that you have the 1.5GHz Ultra 2. The CPU in that NAS is apparently an Intel Atom D405, but that part number isn't mentioned in the Intel D400/D500 Series datasheet. Therefore, I don't know if it's based on the D410 or the D425. If it's in the D425 family, the DDR3 SODIMMs recommended in that other thread should work. If it's in the D410 family, though, you'll need DDR2 memory.
Sorry I missed that the first time I read your question.
Anyway, the supported memory organization is described in Volume 1 of the datasheet on pages 9 and 27-30. As you can see, the largest memory module supported (whether DDR2 or DDR3) is 2GB. The CPUs support 4GB total, but to get 4GB you'd have to install two modules... And there's only one memory-module slot on the circuit board. (That is, there's only one slot on the Ultra 2 Plus circuit board; I guess it's conceivable that the Ultra 2 might have two slots, but I'd be very surprised.)
Again, sorry for the possibly misleading pointer to that other thread, and good luck on your upgrade. - beglitisAspirantThanks fastfwd. I will go for the 2GB module. I like the ReadyNAS form factor and I would ideally like to convert one (either a 4 bay or 2 bay) to a small server. I have succeeded with my NVX but it is 32 bits and goes only up to 4GB. 8GB (or more) with a 64 bit cpu would be perfect particularly with a custom os in the NAS. But that is of course a completely different topic.
- beglitisAspirantFor the record, the memory shipped with the Ultra 2 1.5GHz is DDR3.
- fastfwdVirtuoso
beglitis wrote: For the record, the memory shipped with the Ultra 2 1.5GHz is DDR3.
Good. The DDR3 SODIMMs referenced in that other thread should work fine. - mdgm-ntgrNETGEAR Employee Retired4-bay and 6-bay Ultra/Ultra Plus/Pro would use DDR2, whereas the 2-bay Ultra/Ultra Plus/Pro would use DDR3, I think. The 2-bay models were designed later and also had a USB 3 port on the front whereas the 4-bay and 6-bay models had no USB 3 ports.
