skybum02
Feb 14, 2015Aspirant
Ultra 4 with 4x3Tb drives - ok?
Hello, I have a 2013 ReadyNAS Ultra 4 running RAIDiator 4.2.27. I didn't read the instructions very well when it said the device can support up to 4x 2 Tb drives. Being ambitious I installed 4 x...
vandermerwe
Feb 14, 2015Master
You will be fine with that.
I don't know where you read about a 2 tb drive size limit on the ultra.
The HCL for the legacy units may not reflect what you could actually use. If the unit is out of warranty and you have a backup then I'd use any disks that are listed as compatible with the newer units. Red disks are fine and are on the ultra HCL.
Backup your data.
Backup your data.
