Ney
Nov 22, 2012Aspirant
Ultra 6 Fan speed
Hi, I recently upgraded my ultra 6 to firmware .22 and noticed after a while the fan started to get really loud (when it hits somwhere around 9xx rpm it starts to whine instead of doing regular fan h...
Ney
Nov 23, 2012Aspirant
Could one maybe suggest to have the inaccurate CPU temperature reading as is, and in addition a DTS line desplaying either OK or "Warning CPU above 50C!" It seems rather stupid to delete valuable system info just because it is not accurate enough for thermal protection.
Also if you do not believe/use the thermal readings, how do you throttle the fan speeds?
