tnguyen
Oct 27, 2021Aspirant
Ultra 6 stuck on the ReadNAS promt screen
Hi, Yesterday, i tried to upgrade my Ultra 6 to OS 6 with firmware update in Frontview. First upgraded with PREP4TOR6_0.1-x86.bin and then with R4toR6_6.9.5.bin according to the Ultra 6 OS upgrade g...
tnguyen
Oct 28, 2021Aspirant
Do you mean all this was caused by PSU failure?
Oct 28, 2021Guru - Experienced User
The symptom (stuck on ReadyNAS) is usually caused by a PSU failure - when the 5 volt output is ok, but the 12 volt output has failed. Sandshark can give more info.
- tnguyenOct 28, 2021Aspirant
Thanks for responds and advices.
- SandsharkOct 28, 2021Sensei
There are actually any number of things that can cause this, but a bad PSU is at the top of the list just because it's the usual culprit with an older NAS. While built well, people tend to use a NAS much longer than they would a PC, and the power supply is the same as is used in some mini PC's.
"ReadyNAS" is not a prompt. It's the default display loaded into the display itself, so all it takes is 5V (not not even particularly well regulated) to display that, The CPU doesn't even have to be running. There are two 12V rails in the supply, and while the fan runs on 12V, it also will run without very good regulation. And it could be the 3.3V, too. Unless you test it under load, checking it really won't tell you much. The better thing is to use an ATX supply externally and see if it boots -- even without drives. A newer ATX supply probably won't have enough 4-pin Molex connectors, so you'll need one or more Y cables or SATA to Molex adapters if you plan to use it with the external supply and the drives installed. If you run it for long that way (to get the data off before scrapping it, for example), then cover the internal CPU fan outlet and any gaps the cabling runs through with masking tape to get proper airflow across the drives. If you decide to replace the supply, it's an SFX form factor. While the original is 300W, I recommend at least 350W for the replacement so you have enough 12V capacity. The original had more 12V than is typical for a 300W supply.
Thanks. I have some atx psu and i ll give it a try to see if it works.
Btw, Does OS6 require more power than older OS. It were fine when it ran on 4.x.
No, the OS has little to do with power. The fact that things initially worked when you upgraded to OS6 makes me think it's the drive sync (which does require a lot of continuous power) that's the cause.
BTW, the USB recovery creation works fine in Win10, just run it as administrator. For an updated legacy system, you do need an OS4.2.x style USB recovery with a modified OS6 load file (like you used for the original conversion). The legacy systems can also be very temperamental about what USB devices they'll accept.
