billblom
Jul 18, 2011Aspirant
Ultra 6
I went to the HCL and picked up an initial 3 disks to crank up the ultra.. and it seems to be working rather nicely. Now, 4 weeks later, I went to reorder the disks to fill the system out, and find...
PapaBear1
Jul 18, 2011Apprentice
That is the WD Retail packaging code. WD has a bad habit of using separate number between the retail packaging and the number actually on the drive label. (How fitting WD is buying Hitachi, the other company that does this). The actual model on the drive lable is WD30EZRX.
It is NOT on the HCL at this time. Unless you need to increase the size of the volume at this time, I would wait to see if they are approved at some point in the near future.
