mikeysteam
Jun 17, 2014Aspirant
Ultra add a drive
Sorry if this has been asked many times before but I have been searching and found many over complicated answers, or at least they sound that way as all I want to do is add a second drive to my single...
Marto731
Mike,
Insert 2nd disk. You have data backed up. Factory reset. Pick FlexRAID. You should see a drop down, and you
are picking RAID 0. Data is striped across 2 disks. If one disk fails, you lose data across both. You have one Volume striped across 2 disks.
I work in support. There is less info about RAID 0, as we prefer that customers do not use.
Regards, Marto
Regards, Marto
