Rubatoguy
Mar 15, 2013Aspirant
Ultra Nas 6 with 3 WD 3TB drives only shows 5.5TB
Hello,
I just got an Ultra Nas 6 to replace my NV+ and have equipped it with 3 WD red 3tb drives, however, rather than somewhere near 9TB available, it only shows 5.5TB available....
That seems like quite a bit of overhead...
Did I miss something? I am reading the available TB from the readynas admin home page. No data has been placed on the unit yet.
Todd
Todd
- mdgm-ntgrNETGEAR Employee RetiredTake a look at the X-RAID Volume Size Calculator (see link in my sig).
That is the volume capacity to be expected with 3x3TB disks installed. If any one disk fails your data remains intact. - RubatoguyAspirantYour reply makes sense. Thanks! Interesting that I ended up with about the same usable space with 4 2tb drives in my NV+ and 3 3tb drives in the Ultra 6.
So, given the formula, if you were to fill all 6 drives in the Ultra 6, what drive size would give you the most useable space? - StephenBGuru - Experienced User
That is expected, you can test it with the calculator. To approximate the space, take away the largest drive and sum the rest (3x2TB=6TB, 2x3TB=6TB).Rubatoguy wrote: Your reply makes sense. Thanks! Interesting that I ended up with about the same usable space with 4 2tb drives in my NV+ and 3 3tb drives in the Ultra 6.
Well, you could of course try the calculator... :shock: 6x3TB-> about 15 TB, 6x2TB-> about 10 TB.Rubatoguy wrote: So, given the formula, if you were to fill all 6 drives in the Ultra 6, what drive size would give you the most useable space? - mdgm-ntgrNETGEAR Employee RetiredIf you were to install 6x3TB drives I would recommend using dual-redundancy (if any two disks data remains intact) rather than single-redundancy. Though backups are still required (of course), the extra protection that RAID-6 offers is well worth it.
