Zero-9
May 14, 2019Aspirant
Unable to access shared folders for backup
Hi all
I have an issues with running backups.
I use a cloud solution for backing up data to an offsite vault (Cloud Direct). I have installed the agent via SSH and all seems to be ok and ...
May 14, 2019Guru - Experienced User
Did you install the backup app as root? Or as admin?
Generally you should always log in as root.
Zero-9
Hi, yes I installed as root
- StephenBMay 14, 2019Guru - Experienced User
Perhaps it can't handle BTRFS? The file system isn't listed here: https://livevaultservice.livevault.com/Help/CPT/system_reqs.html
- Zero-9May 14, 2019AspirantI did think that but before we factory defaulted the device we were able to see the files.
