MBerg
Nov 19, 2019Aspirant
Unable to boot ReadyNas Duo - best recovery option?
So I've had my ReadyNAS Duo for probably 10 years now, crazy to think. It's been rock solid. A couple weeks ago, I went to access my drive and the drive could not connect. I also had issues getting t...
Nov 20, 2019Guru - Experienced User
It sounds to me like disk 2 needs to be replaced. If you are running XRAID, the system might be stuggling to resync it. If disk 1 is healthy, you can simply boot up the system w/o disk 2, and then hot-insert a new disk.
If it's been taking three days to boot, then I'd forcibly shut it down - not the best thing to do, but it's not that risky if you are removing disk 2, and you can't wait forever - plus you have extracted the data.
The max disk your system can accept is a 2 TB (and if you want more disk space, you'd need to upgrade both disks to a larger size to get that). If you've never replaced the disks, you might want to replace both anyway. Seagate Ironwolf or WDC Red drives are reasonable choices for your NAS.
You probably should update the firmware when you've taken care of the disks (current version for the Duo v1 is 4.1.16 ). Also, you could set up email alerts that let you know when backups fail (as well as figuring out why they were failing).
One thing you could look into is getting a new ReadyNAS, and then repurpose your Duo as a backup NAS. The current entry level model is the RN212. It would be much faster, and also supports SMB 3 (which matters because both Apple and Microsoft are deprecating the SMB 1 protocol that the Duo uses).
MBerg
Nov 20, 2019Aspirant
OK, thanks for the confirmation and extra info. I was waiting to see what happens on BF to update this too, so it must have heard it was being replaced. I already did upgrade it to the max 2TB back in 2014, so we are good there. Anyways, I turned it off, pulled disk 2 and powered it up this morning. It's not booting and RAIDar doesn't see it, do I need to put in a blank disk? Drive 2 is flashing on the front.
- StephenBNov 20, 2019Guru - Experienced User
Is RAIDar seeing it? https://kb.netgear.com/20684/ReadyNAS-Downloads
- MBergNov 20, 2019Aspirant
It does not any longer. I can still ping it.
- StephenBNov 21, 2019Guru - Experienced User
Ok. Power down and remove disk 1 also (label them so you don't mix them up). Then power up, and see if RAIDar finds it.
If it does, you could then try booting up with only disk 2 in place (in slot 2).
