jinzhongjie
Nov 21, 2017Aspirant
unable to Configuring subversion access over HTTP
root@nas-E5-DD-10:~# apt-get install libapache2-mod-svn Reading package lists... Done Building dependency tree Reading state information... Done Some packages could not be installed. This may mea...
Nov 21, 2017Guru - Experienced User
Are you running 6.9.0 firmware?
jinzhongjie
yes,it is 6.9.0 firmware.
Welcome to ReadyNASOS 6.9.0
Last login: Tue Nov 21 03:08:09 2017 from jin-x230ssf
root@nas-E5-DD-10:~# export HOME=$(pwd)
root@nas-E5-DD-10:~# dpkg -l | grep apache2
ii apache2 2.2.34-0.netgear2 armel Apache HTTP Server metapackage
ii apache2-mpm-prefork 2.2.34-0.netgear2 armel Apache HTTP Server - traditional non-threaded model
ii apache2-utils 2.4.10-10+deb8u11 armel Apache HTTP Server (utility programs for web servers)
ii apache2.2-bin 2.2.34-0.netgear2 armel Apache HTTP Server common binary files
ii apache2.2-common 2.2.34-0.netgear2 armel Apache HTTP Server common files
ii libapache2-mod-auth-token 1.0.8 armel mod_auth_token is a famous apache module that allows you to
ii libapache2-mod-authnz-external 3.2.6-1.netgear1 armel authenticate Apache against external authentication services
ii libapache2-mod-authz-unixgroup 1.0.3-1.netgear2 armel access control based on on unix group membership for Apache
ii libapache2-mod-csrf 1.0 armel adds CSRF protection measures for Apache
ii libapache2-mod-parp 1.0 armel request parameter parser for Apache
- StephenBNov 22, 2017Guru - Experienced User
I see the same issue on my RN526x (also running OS 6.9.0).
I'm not sure there is a good solution, though I guess you could try 6.9.1 (beta, but about to be released).
- jinzhongjieNov 22, 2017Aspirant
Thank you for your suggestion.
I upgrade firmware to 6.9.1.
but it doesn't work.
