jinzhongjie
Nov 21, 2017Aspirant
unable to Configuring subversion access over HTTP
root@nas-E5-DD-10:~# apt-get install libapache2-mod-svn Reading package lists... Done Building dependency tree Reading state information... Done Some packages could not be installed. This may mea...
jinzhongjie
yes,it is 6.9.0 firmware.
Welcome to ReadyNASOS 6.9.0
Last login: Tue Nov 21 03:08:09 2017 from jin-x230ssf
root@nas-E5-DD-10:~# export HOME=$(pwd)
root@nas-E5-DD-10:~# dpkg -l | grep apache2
ii apache2 2.2.34-0.netgear2 armel Apache HTTP Server metapackage
ii apache2-mpm-prefork 2.2.34-0.netgear2 armel Apache HTTP Server - traditional non-threaded model
ii apache2-utils 2.4.10-10+deb8u11 armel Apache HTTP Server (utility programs for web servers)
ii apache2.2-bin 2.2.34-0.netgear2 armel Apache HTTP Server common binary files
ii apache2.2-common 2.2.34-0.netgear2 armel Apache HTTP Server common files
ii libapache2-mod-auth-token 1.0.8 armel mod_auth_token is a famous apache module that allows you to
ii libapache2-mod-authnz-external 3.2.6-1.netgear1 armel authenticate Apache against external authentication services
ii libapache2-mod-authz-unixgroup 1.0.3-1.netgear2 armel access control based on on unix group membership for Apache
ii libapache2-mod-csrf 1.0 armel adds CSRF protection measures for Apache
ii libapache2-mod-parp 1.0 armel request parameter parser for Apache
Nov 22, 2017Guru - Experienced User
I see the same issue on my RN526x (also running OS 6.9.0).
I'm not sure there is a good solution, though I guess you could try 6.9.1 (beta, but about to be released).
- jinzhongjieNov 22, 2017Aspirant
Thank you for your suggestion.
I upgrade firmware to 6.9.1.
but it doesn't work.
