Gopher21
Dec 15, 2020Aspirant
Unable to find manual for ReadyNas model RNR-4C
Does anyone know where I can find the manual for a ReadyNas model RNR-4C
Dec 15, 2020Guru - Experienced User
ReadyNAS part numbers and labels can be confusing, but I think you have an RR2304. If the NAS is operational, RAIDar (and the admin web UI) should give you the model information. Here's an image of the model I think you have:
If I am correct, then you can find doumentation here: https://www.netgear.com/support/product/RR2304.aspx#docs
- Gopher21Dec 15, 2020Aspirant
Thanks Stephan B you are correct the model No. 2304 is shown in the web user interface.
