cboudet
Oct 24, 2022Aspirant
Unable to find readynas duo rnd 2110 v2 on my network and unable to reset to factory settings
Hello, I have a readynas duo rnd 2110 v2 that seems to boot up fine, led's are lit not flashing, but I cannot find it in my network. I have attempted to find it using raidar, and advanced network ...
- Oct 27, 2022
- StephenB
Success!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
I want to thank you because without your help, I would have given up a long time ago.
This nas frustrated me for a couple of weeks straight, but I don't give up easily.
This is what I did in case it helps anyone else.
I had to get an old router and configure it with a static ip of 192.168.168.1 and enable dhcp on it.
Then i configured my laptop to accept dhcp ip assignment and I connected it to the router.
I did an os reinstall on the nas with just disk one and then I connected it to the router.
I started raidar and it found the nas right away, and the setup button was not greyed out.
I got an error about the browser and had to enable my old internet explorer as the default browser, and after that raidar was able to open the frontview interface.
I could not use the browser to set it up and had to use raidar.
I cannot thank you enough for sticking with me and all my questions.
God bless you!
Oct 25, 2022Guru - Experienced User
The issue with RAIDar might be caused by security software on the PC
cboudet wrote:
Last night I found out why I had not been able to reset the nas.
The label at the bottom said it was an rnd 2110 v2 , so I thought it was version 2 but it is a version 1 readynas duo and the reset procedure is a little different for it.
Yes, the procedures are different (and the labeling is confusing). Note if you did the factory default procedure, the system would reformat the disks - so you would lose all the data. Hopefully you actually did an "OS reinstall".
cboudet wrote:
I tried through the browser using 192.168.168.168 and still cannot connect.
That is because you have a 10.0.0.x network. It is possible to connect the NAS directly to a PC over ethernet (with no router). But if you do that, you also need to manually configure the network on the PC before you can connect.
You can get to the settings in Win10 by
- going to "network and internet" in the control panel
- Select "change adapter settings"
- Select the ethernet adapter
- select "change settings of this connection"
- Select "Internet Protocol Version 4 (TCP/IPv4)
- click on "properties"
From there, select the "alternate configuration" tab. and fill it out like this:
Then you can browse to https://192.168.168.168/admin
However, there was a change in the internet browsers a few months ago that will get in the way. Your NAS uses TLS 1.0 for HTTPS connections, and browsers now require TLS 1.2. Chrome, Firefox, Edge, etc will give you an SSL protocol error and/or a Cipher mismatch when you try to reach frontview.
You can
- Use Internet Explorer if that is installed on the PC
- Use Edge in IE mode ( see https://pureinfotech.com/enable-ie-mode-microsoft-edge-chromium/ )
- Download an old version of Firefox (94.0.2 works), and configure it to not auto-update. Then use FireFox to access the NAS
cboudet
Oct 25, 2022Aspirant
Ok, I think I am one step closer to getting in the nas frontview panel.
I configured the IP as you suggested, and connected it to the laptop.
I did another os reinstall and as soon as the two disk led's lit solid, I opened RAIDar and it found it!
But a few seconds later it disappeared and the raidar help screen shows with the last three messages blinking:
awaiting resync
life support mode
background task active
And I cannot open frontview.
I don't understand, because both the power light and both disk lighta are solid, and the activity light is not lit.
would changing to new disks make it work?
Thanks
- StephenBOct 26, 2022Guru - Experienced User
awaiting resync
life support mode
The NAS boots from the disks, so switching to new disks should resolve this.
You could also try powering down the NAS, and removing disk 1. Then boot up with slot 1 empty, and see if it boots normally.
- cboudetOct 26, 2022Aspirant
Thanks,
I thought it booted from the hardware.
I will try that tonight.
I have noticed disk 1 led goes solid fairly quick, but disk 2 seems to take all night to go solid.
Should I remove disk 2?
And does the disk need to be formatted before placing it in the nas?
Thanks
Another question, sorry.
Will that nas (I think is readynas duo version 1) accept two 2 terabyte disks?
Thanks!
cboudet wrote:
Thanks,
Normally the system boots from disk 1, so I'd try that first.
If that doesn't change anything, then try powering down again, reinserting disk 1, and removing disk 2.
Be careful to power down before removing or inserting disks - you don't want to trigger resyncs accidentally, as that can result in a failed volume.
cboudet wrote:Will that nas (I think is readynas duo version 1) accept two 2 terabyte disks?
2 TB is the max. I recommend either WD Red Plus or Seagate Ironwolf. Don't go with the current WD Red drive (WD20EFAX) as it is SMR. Many of the newer desktop drives in this size range are also SMR, so I recommend sticking with the two options above.
Sorry I don't know what SMR is. And how can I tell when I am lookin at a disk?
I removed disk 2 and it did not work. The disk 2 led kept flashing.
So I installed two new 2 tb disks, I need to wait until it finishes to see if they work.
Is it critical to use the recommended disks? I think I checked the list when I bought these, but I don't remember, it has been a few years.
- StephenBOct 27, 2022Guru - Experienced User
Shingled Magnetic Recording.
- https://en.wikipedia.org/wiki/Shingled_magnetic_recording
- https://arstechnica.com/gadgets/2020/04/caveat-emptor-smr-disks-are-being-submarined-into-unexpected-channels/
That is contrasted with CMR (Conventional Magnetic Recording).
Both Western Digital and Seagate now have SMR/CMR on their data sheets (in response to sharp criticism like the arstechnica article above).
Personally I wouldn't use an SMR drive in a NAS. So I'd check that. If your drives were purchased some years ago, then there is a good chance they are CMR.
If you mean Netgear's hardware compatibility list when you say "the list", then checking that is a waste of time. The list is very out of date. So I now recommend CMR NAS-purposed drives (like the Red Plus and Ironwolf) or enterprise class. Other drives might well work, but these are safe choices.
- cboudetOct 27, 2022Aspirant
Thanks for the information.
I don't know if this is going to help determine what is wrong, but It seems like the raidar is able to find the nas for about one minute while it is booting up, but after about a minute or less, it does not find it and shows a help screen.
I took a couple of screen captures so you can see what I see.
I have only been able to accomplish this after doing an os reinstall with the laptop connected directly to the nas ethernet as you suggested.
I have not been able to find it through the browser.
Is there a way to reinstall the firmware with a usb drive without logging in the normal way?
There is a USB recovery process, but I am not sure if that will help or not.
When the system is no longer detected, are you seeing a blinking LED pattern?
LED blink behavior for 2 disk systems is three quick blinks of all disk LEDs and the backup LED, followed by an 1s delay, followed by a number of slow blinks. The number of slow blinks will be the error code. Current error codes: 1 - Vendor mismatch 2 - No disks detected 3 - Bad contents on root partition of disks 4 - Flash error 5 - Unsupported RAID configuration - cboudetOct 27, 2022Aspirant
No blinking led's.
It shows the two disc led's solid
- StephenB
God bless you!
