cboudet's avatar
cboudet
Unable to find readynas duo rnd 2110 v2 on my network and unable to reset to factory settings
Hello, I have a readynas duo rnd 2110 v2 that seems to boot up fine, led's are lit  not flashing, but I cannot find it in my network. I have attempted to find it using raidar, and advanced network ...
  • cboudet's avatar
    cboudet
    Oct 27, 2022
    • StephenB
    Success!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
    I want to thank you because without your help, I would have given up a long time ago.
    This nas frustrated me for a couple of weeks straight, but I don't give up easily.
    This is what I did in case it helps anyone else.
    I had to get an old router and configure it with a static ip of 192.168.168.1 and enable dhcp on it.
    Then i configured my laptop to accept dhcp ip assignment and I connected it to the router.
    I did an os reinstall on the nas with just disk one and then I connected it to the router.
    I started raidar and it found the nas right away, and the setup button was not greyed out.
    I got an error about the browser and had to enable my old internet explorer as the default browser, and after that raidar was able to open the frontview interface.
    I could not use the browser to set it up and had to use raidar.
    I cannot thank you enough for sticking with me and all my questions.
    God bless you!
ProSupport for Business
