kontech's avatar
kontech
Unable to manage NETGEAR ReadyNAS 3138
A new NETGEAR ReadyNAS user here just purchased NETGEAR ReadyNAS 3138.
Device appears to be online, can ping its IP but cannot manage it via URL: https://IP address/admin. ReadyCloud is'nt finding it either. Not a good start.
  • StephenB's avatar
    Do you have disks installed? What is the status of the health LED on the front panel?
    If this is a new NAS (not pre-owned) then you are entitled to installation support via my.netgear.com.
    • kontech's avatar
      kontech
      I've tried with a and w/o disks and different Ethernet ports. The power and LAN LEDs have been flashing (green).
      After pushing reset button with a pin power LED is now solid green I was ablet to get in.
      It's a brand new device. Firmware 6.10.4
      Any ideas what the problem could have been?
      • StephenB's avatar
        kontech wrote:
        I've tried with and w/o disks
        Linux and the NAS application are installed onto the disks.  So you can't access the web ui if disks are not installed.
        There can be a "dead" time when the NAS is first installing the OS onto the disks.  So that is one possibility - but I really can't tell if that was the cause or not.
ProSupport for Business
