Nord3628's avatar
Nord3628
Unable to set up ReadyNAS Duo RND2110v2
Hello, I'm looking for help setting up my NAS Duo. RND2110 v2   F/W = 4.1.6  Operating under Windows 10 (21H2) Serial number 24M39A7C00CAB 1.  I'm confused as to what version i actually have. I b...
  • StephenB's avatar
    Jul 28, 2022
    Nord3628 wrote:
    Thank you,
    Something in the back of my mind suggested something like that.
    I have done a complete factory reset.
    There are 2 HDD's that are blank unformatted with no partitions or file system on them.
    I cant remember how to set off the disk initialisation.
    Can you point me at any documentation that covers that?
    Note you cannot do a factory reset unless the disks are installed.  Also the max disk size supported in your NAS is 2 TB.
    In general, if you want to use the default XRAID (RAID-1), all you need to do is put the unformatted disks in the NAS and power it up.  That will automatically do a factory install.
    Documentation is here: https://www.netgear.com/support/product/RND2000v1_(ReadyNAS_Duo_v1).aspx#docs
ProSupport for Business
