Nord3628
Jul 23, 2022Aspirant
Unable to set up ReadyNAS Duo RND2110v2
Hello, I'm looking for help setting up my NAS Duo. RND2110 v2 F/W = 4.1.6 Operating under Windows 10 (21H2) Serial number 24M39A7C00CAB 1. I'm confused as to what version i actually have. I b...
- Jul 28, 2022
Nord3628 wrote:
Thank you,
Something in the back of my mind suggested something like that.
I have done a complete factory reset.
There are 2 HDD's that are blank unformatted with no partitions or file system on them.
I cant remember how to set off the disk initialisation.
Can you point me at any documentation that covers that?
Note you cannot do a factory reset unless the disks are installed. Also the max disk size supported in your NAS is 2 TB.
In general, if you want to use the default XRAID (RAID-1), all you need to do is put the unformatted disks in the NAS and power it up. That will automatically do a factory install.
Documentation is here: https://www.netgear.com/support/product/RND2000v1_(ReadyNAS_Duo_v1).aspx#docs
Jul 23, 2022Guru - Experienced User
Nord3628 wrote:
1. I'm confused as to what version i actually have. I believe it to be a version 1 despite it being badged as v2?
Correct, it's the original version (called a v1 here). A v2 would run 5.3.x firmware.
Nord3628 wrote:
3. I have tried the various netgear admin logons that I know but its not letting me in, does anyone have any ideas?
Pretty sure it was admin and netgear1
The default username is admin; the default admin password is netgear1. So that is correct. Note you need to log into https://nas-ipaddress/admin to get into frontview (the web admin ui). If you leave the /admin out, you will end up on an empty shares page.
Are you getting to the point where you can enter the username/password? Or are you getting an SSL protocol mismatch error?
Do you know for sure that it is still running 4.1.6 (likely the previous owner upgraded it to something newer). The final firmware was 4.1.16.
If you are trying to access it from explorer, then you need to enable the SMB 1/CIFS client on the PC. You can do that from "turn windows features on or off".
