donagu
Sep 30, 2020Follower
Unable to upgrade OS on RN104 from 6.4.0 to 6.5.2
Hello, My RN104 has been offline for 3 years or so. When I fired it back up, I reset it to factory default. The OS informed me that there is a new OS 6.5.2, but was unable to install. I tried ...
Oct 01, 2020Guru - Experienced User
donagu wrote:
I tried installing manually, but got a "Unrecognized server error." popup.
Try rebooting, and see if the 6.5.2 firmware is installed anyway.
Once it is installed, you will find there is newer firmware (6.10.3 is current). But it is important to install 6.5.2 first, you can't jump directly from 6.4 to the current firmware.
