jljeeper
Jan 13, 2013Tutor
Unexpected enclosure status detected
I have been getting these messages (below) over the past two days. Between 3-5am. The NAS is inside my stored RV with no heat and it has been colder than normal 18-20F lowest temps. But I am getting o...
Marto731
Jan 13, 2013Aspirant
jljeeper,
This looks like a chassis fault. Can you open a support ticket, details below.
Can you attach NAS logs, (Status > Logs > Download all logs ),
for Tech Support analysis.
You may be able to recalibrate Temp reading, under Volume settings.
Regards, Marto
Regards, Marto
