Numb3r6
Feb 14, 2015Apprentice
Unexpected RAID Sync on Volume C
If anyone can offer any suggestions as to why this has happened I'd be most grateful My ReadyNAS is set up to start in the morning, and shut down late each night. Never been an issue. Only historical...
Numb3r6
StephenB wrote: I'd check the SMART stats for both disks, and also look at the logs.
Thanks for that. I'd forgotten there was some more detail in the SMART+ option. I can't see anything there that really grabs my attention. The only one that seems abnormal is a single High Fly Write on 1 disk. All the other parameters that suggest errors etc. are fine.
Also the Frontview logs are green all the way. Are there other logs I can access directly via the file system maybe?
