jcs1
Jul 20, 2011Follower
Unreasonable remote access terms
Hi, While dealing with an issue with support on a readynas, I was sent the following: I hereby authorize support personnel or authorized representatives of NETGEAR, Inc. and its subsidiaries ...
mdgm-ntgr
Dec 23, 2011NETGEAR Employee Retired
If you're not happy with the terms they offer, then restore your data from backup. No one's forcing you to use the service.
I cannot remember any case of a claim made on the forums of NetGear support engaging in "wrongdoing or negligence of any kind" when they use tech support mode. They are professional.
