sm7ovk
Apr 28, 2012Aspirant
Update of disc firmware?
Hi, Is it possible in any way to update the disc-firmware when the disc's are in my ReadyNAS duo? If not, is it possible to connect the disc to a computer and upgrade even if it's not formatted as a ...
mdgm-ntgr
Apr 28, 2012NETGEAR Employee Retired
You'll need to hook the drives up to a PC to do the firmware upgrade.
Whilst drive firmware upgrades should leave data intact drive manufacturers typically recommend you backup the data on your disks as a precaution first.
