sm7ovk
Apr 28, 2012Aspirant
Update of disc firmware?
Hi, Is it possible in any way to update the disc-firmware when the disc's are in my ReadyNAS duo? If not, is it possible to connect the disc to a computer and upgrade even if it's not formatted as a ...
sm7ovk
Many thanks for your fast replies!
I did look for old postings but I didn't found this.
I think I bought the disc's very soon after they were on the compability list so I might have got disc's with older firmware. Since I just have had a problem with three :shock: Seagate disc's casued by firmware I'm very careful - especially since the ReadyNAS contain my photo backups! I'll try this asap and since I have two disc's I'll upgrade them one at the time so I can check if I loose any data in the proces. (I'll do an extra backup for sure on a third disc... )
Thanks for the help!
