sm7ovk
Apr 28, 2012Aspirant
Update of disc firmware?
Hi, Is it possible in any way to update the disc-firmware when the disc's are in my ReadyNAS duo? If not, is it possible to connect the disc to a computer and upgrade even if it's not formatted as a ...
ianch99
May 03, 2012Aspirant
For what it is worth, I bought two HD204UI drives last Dec and I was concerned if I had to update the firmware as well. I contacted Segate support quoting the serial numbers and they said:
so I did not bother (only have a Mac at home). So far, no problems. They are good drives and run cooler than the 1TB Seagate ones they replaced
Thank you for contacting Seagate.
We checked our system and your drives are not affected by a firmware problem.
