pw_ng
Jan 24, 2019Aspirant
Upgrade from NV+ to 424 (kind of URGENT!)
Help!
I have an old NV+ which has died. I guess power supply problem, because the unit is lifeless.
It was time for an upgrade anyway, so I bought a 424, for use with the same set of 4 x 2TB...
pw_ng
Thank you very much.
Thing is, my ReadyNAS NV+ chassis is dead. Do I need a working NV+ chassis in order to recover the data from the disks?
The website here is not very clear at all, so I hope NETGEAR support can tell me what I need to do.
Jan 24, 2019Guru - Experienced User
If you use the process in the KB article I posted above then you don't need a working NV+ chassis.
What do you find unclear in the KB link?
Personally I find some lack of clarity around the costs, but the process looks clear to me.
