mrbrown66
Jun 29, 2018Aspirant
Upgrade from RN104 to RN214
Hey guys,
I have an 4 bay RN104 on the latest firmware (6.9.3) and I am upgrading to an RN214 which is arriving shortly. Is it possible to move my 4 existing drives across and put them in the same slot order and it will simply work? Or not possible and need to backup and start with a fresh partition?
Thanks,
Mrb
That works.
Though if you have a spare disk handy, you could do a fresh install on the disk, and (if needed) update the firmware on the RN214 first. Then power down and migrate the disks.
That works.
- mrbrown66Aspirant
Thanks I will try that - I probably have an old drive around I can use too to upgrade the firmware.
