mattebury
Jun 04, 2012Aspirant
Upgrade HDD or get new device
Hello, I currently have a ReadyNAS NV+ with 4-500GB drives that is rapidly approaching size limits (about 100 GB free, raid 5 configuration). This device is used at home to store all our music, ...
Jun 04, 2012Guru - Experienced User
I am not sure what "play nicer with MAC OSX" means to you. Is there something you can't do now that you would like to do?
If you are happy with the current speed of your NAS, then yes, it is worthwhile to invest the $500 in it. Upgrading your current NAS is the cheapest way to get more storage. If the NAS fails before the disks, you can reuse the disks in a new machine. This all assumes you have a backup strategy in place.
BTW, I'd buy three 2 TB disks instead of four 1 TB, and leave one slot open for expansion.
For about twice that investment you can get an new Ultra 4 (with $500 worth of disks). You get a much faster NAS, support for 3 TB drives, the ability to use ReadNAS Photos 2, and some other features. The management interface is pretty similar to the UI you are already used to.
If you buy a new NAS, I agree with the posters who think you should keep the existing NV+ in service (possibly backing up critical files on the Ultra). I currently use a Pro-6 as my main NAS, and use an NV+ and a Duo to back it up. The older machines are working well, and I see no reason to replace them.
BTW 2, if you are using 100 mbit ethernet then your speed is limited by the network, not your NV+. So if performance is an issue, you should upgrade to a gigabit network as well. Gigabit switches are inexpensive, and will play nicely with your existing router. You also need to get cat 5e or cat 6 ethernet cables.
