wgotten
Mar 30, 2013Aspirant
Upgrade NV+ v1 or buy v2
Greetings all, I have a NV+ v1 (originally with 4 x 1TB drives) that is still working fine. Have replaced 1 of the 1TB drives with a 2TB drive, and am starting to approach capacity. Running Apple...
Mar 30, 2013Guru - Experienced User
I agree that if your current is all you need, you might as well stick with it for a while longer. If you do upgrade, consider using your v1 for backup.
As far as upgrades go, personally I would pass on a v2. It has some features you don't have now, but also takes some features away.
If you are ok with your current functionality, and want the lowest cost, than an x86 Pro or Ultra could be a good deal. They are being phased out, so resellers are starting to clear inventory.
Or get something in the RN1xx/3xx/5xx family.
