brandtz
May 08, 2012Aspirant
Upgrade to 3 Gb disk ?!
Have a reday NAS DUO with 2 GB disk. Now need to upgrade to two 3 GB disks to get more space AND mirroring. Added "ForceExpansion" that said OK. Inserted one 3 GB disk and it says, faulty disk, ...
May 09, 2012Guru - Experienced User
Netgear regrettably created a lot of confusion when they branded the ARM units as "v2" - since as you discovered, they had used "v2" already for the original Duo model number.
brandtz wrote: Model: ReadyNAS Duo [X-RAID], Serial: 24M3027R02D00, Firmware: RAIDiator 4.1.6 [1.00a043]
I think it is a V2 actually?!?! How can I tell?
Since you are running 4.1.6 firmware, you absolutely have a sparc-based unit, which is called "v1" throughout the readynas forums and main readynas page.
So it does not support 3 TB drives.
